Audit logs for Request Attributes
Hi All,
Is there a way that we can find the revision history for Request Attributes ???
Tried through Audit logs , but seems like it doesn’t work for Request Attributes.
Manaswini
@ManaswiniSetti There isn’t a version history in the Settings UI at this point in time. You can use the Audit logs however. I’ve done a test where I created a RA, and then edited it. If you are using SaaS, you will only have a 30 day lookback.
I recommend leveraging the Unique RA ID:
This will allow you to grab ALL of the available audit logs for that given RA:
