Hi team,
Having the following query:
timeseries value = avg(dt.cloud.azure.vm.cpu_usage), by: {azure.location, azure.management_group, azure.resource.name, azure.subscription, azure.vm_scale_set.name, dt.entity.azure_region, dt.entity.azure_vm, dt.source_entity, dt.source_entity.type}
| filter contains(azure.resource.name, "primary00") or contains(azure.resource.name, "primary01")
| parse azure.resource.name, "LD 'primary0' INT:number"
I’d like to get in a timeseries the average of the arrays by number. Meaning, for all arrays with number==0, an average of the values of the arrays and the same for number==1.
How could I achieve this? arrayAvg doesn’t seem to work for this use case.
Thanks in advance!
You need to use integrative expressions in summary command.
| summarize {value=avg(value[])}, by: {interval, timeframe, number}
This query will give 2 timeseries for 2 possible values of “number”. Of course you can split data as you with by adding more of available dimensions retrieved by timeseries command.
Please also take a look a other examples in our documentation: DQL timeseries examples for Metrics — Dynatrace Docs
