A: We don’t differentiate between enabled or disabled workflow. Any workflow that exists can be executed at any time, either manually or via API, even if a starting condition like a trigger or schedule is defined.
I think there’s a relatively simple fix for this. The issue the op is talking about is that this pricing model discourages development, and I totally agree. However, I also understand that you have to charge for disabled workflows due to the fact that they can still be executed by other workflows and the API.
So, why not have another setting for a workflow called “In Development”. This could be the default setting for a workflow (that way when a user creates a brand new workflow they don’t have to remember to set this and thus accidentally start incurring charges despite the fact that it probably isn’t being used yet, as stated in the op’s original problem statement here).
You could make it so that “In Development” workflows cannot be executed or ran other than from the web GUI for testing purposes. Or, even better, to keep it simple, have the Run button be greyed out when the workflow has "In Development" mode turned on and, when a user hovers over the Run button to see why it’s greyed out, you could have a tooltip that informs them that they need to turn off the “In Development” setting to run their workflow for testing. You can then have a pop-up occur when a user saves a workflow informing them about the “In Development” toggle and the implications it has on licensing and the ability to run it (for example, if it’s currently toggled on, inform them that they will not be able to Run this execution until this setting is toggled off, but that they will not occur any licensing costs while it is on. Conversely, if the setting is currently off when they save the workflow, the pop-up could warn them that, even though the workflow may be disabled, they will still incur charges unless they turn the "In Development" setting on).
You could also set it so that it could not be toggled from “In Development” to “Disabled” or “Enabled” from the API to prevent users from abusing this setting by using other automation worflows to turn this mode on/off to get around your billing. Just configure it so that the “In Development” mode can only be turned off/on from the Workflows App web GUI.
This would solve the originally stated issue of letting people develop and “play around” with Workflows (which is what you want for a new product, I would think) without companies having to worry about incurring unnecessary costs for workflows that may never be used and it would still allow Dynatrace to keep this billing model that doesn’t charge for each execution of a workflow (which I appreciate because, as you stated, that could stack up real fast).
