AWS Alarm
Looking for a feasibility to monitor AWS Alarm, since this is not available in the services list other than default.
Thank you in advance.
You can raise a product idea about it.
Best regards
Hi @munawarhossain1
You can use the AWS API to retrieve data about these alerts. Then, using the DT API Ingest Metrics, put these metrics into DT.
Radek
Thanks @radek_jasinski
So, on this do we need an AG hosted in AWS? or possible to go via default way?
