AWS:
You have two options:
- Option 1.
Confirm that all ActiveGates that have AWS monitoring enabled can connect to AWS.
In case of role-based setup: Ensure that all ActiveGates that have AWS monitoring enabled have theActiveGaterole attached. - Option 2.
Choose one ActiveGate you want to monitor your AWS account with. Any ActiveGate type will work as long as it can connect to AWS. On that ActiveGate edit thecustom.propertiesfile and set the following property totrue:
[aws_monitoring]
aws_monitoring_enabled = true
On all the other ActiveGates, set the property to false.
Azure:
If you have more than one ActiveGate, you have the following options:
- Confirm that all ActiveGates with Azure monitoring enabled can connect to Azure.
On the designated ActiveGate, edit the
custom.propertiesfile and set theazure_monitoring_enabledproperty totrue:[azure_monitoring] azure_monitoring_enabled = true -
On the other ActiveGates, edit the
custom.propertiesfile and set theazure_monitoring_enabledproperty tofalse.ActiveGate version 1.261+ Designate an ActiveGate with which you want to monitor your Azure subscription. Any ActiveGate type works properly as long as it can connect to Azure.
