Single ActiveGate to monitor multiple AWS accounts
Hi everyone,
I’m looking for documentation that explains how to use a single AG (or two for HA) to monitor multiple AWS Accounts.
Thanks in advance
You can enable / disable that module in the ActiveGates configurations.
For example, if you have 2 AGs, and you want only want is being used for AWS integration, you can disable that module in custom.properties file.
Best regards
Hi @medd ,
Does the solution from @AntonPineiro work in your case? If yes, please make sure to select the “accept as solution” button below his reply, and if not, let me know, and I’ll look for some further assistance :blush:
