Awscodepipeline over Jenkins project with performance signature
I’m trying to integrate aws code pipeline over a Jenkins project and not a pipeline since the awscodepipeline plugin doesn’t have a pipeline alternative and use the performance signature plugin that is only meant for Jenkins piplelines. is there a workaround to using the Dynatrace plugin in a Jenkins project instead?
I’m not sure what you are trying to do.
Not clear what you are trying to do.. but
AWS - Unbreakable DevOps Pipeline: Shift-Left, Shift-Right & Self-Healing
Jenkins Performance signature - Shift-Left in Jenkins: How to implement Performance Signature with Dynatrace
Native jenkins + Dynatrace CLI - https://github.com/dynatrace-innovationlab/jenkins-dynatrace-pipeline-tutorial
you may also consider: Push deployment events from Jenkins — Dynatrace Docs
It seems you want to use a Freestyle jenkins project that is not a pipeline project, use the Native jenkins link and adapt the steps in the pipeline (sh steps) as steps in your freestyle project.
No, the plugin can only be used with a jenkins pipeline, not with a Freestyle Project.
But you can have a look at Pitometerm which you could use in your jenkins project to do a performance signature without the plugin.
The accepted answer is an option but the Dynatrace CLI readme states: "The CLI now implements the main uses to gather and compare metrics as part of your CI/CD Delivery Pipeline. All gathered and compared data will end up as a Custom Device with Custom Metrics in Dynatrace, e.g: “My Jenkins Pipeline” with metrics such as “Response Time”, “Throughput” or “Number of Incoming Dependencies”.
