Dynatrace - Jenkins Plugin
Hello, i have just installed the latest version of “Performance Signature with Dynatrace for Jenkins” (GitHub - T-Systems-MMS/perfsig-jenkins: Performance Signature with Dynatrace for Jenkins · GitHub)
on my Jenkins server. Unfortunately, I can not add a new Dynatrace API token. Is this problem known to you and is there a solution?
A workaround is to create the Dynatrace API Token in the Jenkins credentials setting. It then is available to choose when configuring the Dynatrace Server.
I also ran into this issue a few times, a fix would be great.
This is a known bug in the Credentials Plugin: https://issues.jenkins-ci.org/browse/JENKINS-42546
One workaround is to save the global settings and use the add credentials button afterwards.
