Dynatrace Jenkins Plugin
I’m trying to integrate Dynatrace with Jenkins DevOps activity. Therefor, I need metrics details for some basic checks of deployed build. How do I fetch the metrics details by using Jenkins Plugin? I don’t want to go for the Dynatrace Rest API option because I may need to take more time for processing and finding required data from huge JSON response.
Kindly help me to get the Jenkins plugin to fetch metrics details.
Hi @Shruts
I don’t think you’ll be able to do this without using the API.
You can also look at plugins in Dynatrace HUB
Radek
