Background color option in problem widgets
Hi all,
I am doing a script that uses the API to update a existing dashboard but i am having a problem:
  • I want to have a background color option(image below) in problem widgets on when i do it, but every time i use the script to do a update, the background color option turns off on  all problem widgets.
Is there a way to pass the background color=On on the payload?
Hi @RM,
I think it’s not available yet, you can find the following link for an idea related to the same topic, you can vote for it.
https://community.dynatrace.com/t5/Product-ideas/Impossible-to-switch-on-quot-background-color-quot-green-red-in/idi-p/203906
