Best Way to Convert Date Strings to Timestamps in Dynatrace DQL?
Hello Team ,
I have a field in my logs that contains the date and time, but the field type is a string. Is there a way to convert this field into a timestamp? I tried the totimestamp function, but it isn’t working. The field is in the format MM/DD/YYYY HH:MM:SS.
Please let me know if anyone has a solution for this?
Akhil Jayendran
You need to use the parse command and DPL with timestamp matcher:
data record(str="11/30/2025 08:02:20")
| parse str, """TIMESTAMP("MM/dd/yyyy HH:mm:ss"):ts"""
