Convert a string metric dimension from SQL extension to timestamp
I have metric dimension, start_time coming from SQL extension which is a string, format is   ‘mm/dd/yyyy hh24:mi:ss’. I need to convert it to timestamp and then get the duration from the current time to identify if the job is running long. Could anyone please help how can I convert this string to timestamp ? Thanks in advance.
Have you tried using the toTimestamp() DQL function? It should meet your needs.
Yes, thats what I have used and it solved the problem :slightly_smiling_face:
