Unable to convert event.start from fetch bizevents into timestamp using timestampFromUnixNanos
Hi All
I have this DQL which produces the desired output:
fetch bizevents
| filter event.type == “cost.list.spend”
| lookup [fetch dt.entity.host | fieldsAdd entity.name,osArchitecture,osType],sourceField:dt.entity.host,lookupField:id,prefix:“host.”
| fieldsAdd event.start_timestamp = timestampFromUnixNanos(event.start)
However I am unable to convert event.start into a timstamp using timestampFromUnixNanos
As per the documentation here: Business Analytics — Dynatrace Docs
event.start string  stable The event start timestamp in UTC (given in Grail preferred Linux timestamp nano precision format).
The value in my DQL output for event.start in this case is  1740622469442 so there is a value there (translates as 27 February 2025 15:20:45 )
Am I using the correct function? Any suggestions appreciatedThanksAlan
It’s a string (green)
| fieldsAdd timestampFromUnixMillis(toLong(event.start))
Thanks Mark
You are correct in both instances - it needs to be converted from a string and i need to use timestampFromUnixMillis instead
Appreciate your time
Regards
Alan
