Transform timezone with DQL
Hi team
We have noticed that the dt.system.events are ingested with a different time zone. Is it possible to transform the timezone with DQL here?
I tried using bin(timestamp,24h,at:-1h), but with the change of hour, it gets desynchronized.
Thanks in advance!
Yes, it is possible in DQL, but not by using bin(timestamp, 24h, at: …).
bin(…, at: -1h) behaves like a fixed offset, so it does not adjust for daylight saving time. That’s why it becomes misaligned after the time change.
A better approach is to build the local day using timezone-aware functions, for example:
fetch dt.system.events
| filter event.kind == "BILLING_USAGE_EVENT" AND
    in(
      event.type,
      array(
        "Full-Stack Monitoring",
        "Infrastructure Monitoring",
        "Foundation & Discovery",
        "Mainframe Monitoring"
| dedup event.id
| fieldsAdd billed_units = coalesce(
    toDouble(billed_gibibyte_hours),
    toDouble(billed_host_hours),
    toDouble(billed_msu_hours)
| fieldsAdd unit_price_eur =
    if(event.type == "Infrastructure Monitoring", toDouble(1),
    else: if(event.type == "Foundation & Discovery", toDouble(1),
    else: if(event.type == "Full-Stack Monitoring", toDouble(1),
    else: if(event.type == "Mainframe Monitoring", toDouble(1),
    else: null))))
| fieldsAdd estimated_cost_eur = billed_units * unit_price_eur
| fieldsAdd local_year  = getYear(timestamp, timezone:"Europe/Madrid")
| fieldsAdd local_month = getMonth(timestamp, timezone:"Europe/Madrid")
| fieldsAdd local_daynum = getDayOfMonth(timestamp, timezone:"Europe/Madrid")
| fieldsAdd local_day = timestamp(
    year: local_year,
    month: local_month,
    day: local_daynum,
    hour: 0,
    minute: 0,
    second: 0,
    timezone: "Europe/Madrid"
| summarize `Application and Infrastructure Observability` = sum(estimated_cost_eur),
    by: { event.type, local_day }
| sort local_day asc
Then you can aggregate by local_day.
For display purposes, you can also use:
formatTimestamp(timestamp, timezone:"Europe/Madrid")
The statement that “dt.system.events are ingested with a different time zone” is incorrect. Timestamp is Grail is stred in universal time, so timzonel-less and can pre presented in any timezone. The problem is caused by use of bin().
The easies solution is to use makeTimeseries or time alignement operator @ . Both them are user timezone aware. To example queries:
| makeTimeseries cnt = count(), by: {event.type}, interval:24h
and
| summarize cnt = count(), by: {event.type, timestamp = timestamp@d}
