Bounce rate analysis on a dashboard
On this page, there is an example of a bounce rate analysis:
This seems helpful and I would like to put this on a dashboard. The problem is there is no way to do this. I’m sure I can do this in USQL, but then that seems like a waste of time.
Thoughts?
HI JGannon,
there are multiple options to have access to bounce rate information on a dashboard:
  1. Create a chart in Data explorer using the Bounce rate (by users, user type) [web] metric.
  2. Add a Markdown tile on your dashboard where you link the bounce page
  3. Create a USQL chart on your dashboard
Hope this helps!
