I want to get the bounce rate that are given in the bounce rate table using USQL query :
HI,
where you want to get it? It is not clear to me.
You want to get the bounce rate showed via USQL in a dashboard? If yes, gen2 or gen3?
@Pranjal17 here you go, there was another community post with the same question https://community.dynatrace.com/t5/Dashboarding/Bounce-rate-analysis-on-a-dashboard/m-p/199314/highlight/true
@manos-saratsis Thanks .
