Hello, can we test our app to see the behavior with multiple users at the same time?
I don’t actually need to test different users, it could be the same user and the same location, but I want the events to happen an X number of times at the same time.
Please advice.
I am not sure if I understand you but you can duplicate synthetic monitor. You can choose same or different user.
Best regards
Do you want to run a load test with synthetics?
Yes, exactly. But only on one location. And it would be nice to not create 100 browser monitors if I want to test the performance of 100 users at the same time.
I don’t think you will be able to ensure that all 100 browser monitors run at the same time.
Try using load testing tools like JMeter Netload or LoadRunner, there are instructions to integrate with Dynatrace in the docs:
https://docs.dynatrace.com/docs/platform-modules/automations/cloud-automation/test-automation
