Browser Monitors: How to enable 3rd Party cookies
Summary
Since Chromium version 122, third-party cookies are blocked by default. This can cause Dynatrace Synthetic Browser Monitors to behave differently from real-user browsing sessions, resulting in pages failing to load, authentication issues, or incomplete transactions.This article explains how to identify when blocked third-party cookies are causing Browser Monitor failures and how to enable third-party cookies for local playback and Private Synthetic Locations.
Problem
A Dynatrace Browser Monitor doesn’t load a website as expected, even though the site works correctly when accessed manually.Browser Monitor screenshots may show incomplete rendering or failure messages caused by required third-party cookies being blocked.Because Chromium 122 blocks third-party cookies by default, websites that rely on them may not function correctly during Synthetic execution unless this behavior is explicitly disabled.
Resolution
Local playback
There are two supported approaches.
Option 1: Disable Third-Party Cookie Blocking in Chrome Incognito
  1. Open an Incognito window.
  2. Navigate to Chrome privacy settings.
  3. Disable Block third-party cookies.
    This setting persists for future local playbacks.
Option 2: Allow Third-Party Cookies for Specific Sites
  1. Open Chrome.
  2. Navigate to chrome://settings/cookies
  3. Add the affected website domain to the list of sites allowed to use third-party cookies.
To allow third-party cookies in Private Synthetic Locations, disable Chromium’s third-party cookie protection feature by using the startup parameter:--disable-features=TrackingProtection3pcd
Cluster Version 315 and Later
No configuration changes are required.Starting with Cluster version 315, the TrackingProtection3pcd Chrome feature is disabled by default.
Important
If you previously customized the Browser Monitor configuration using the procedure for older cluster versions, review and remove the custom configuration where appropriate so that the default feature list can be used.
Cluster Versions Prior to 315
Step 1: Identify Existing Disabled Features
  1. Locate the vuc-browser.log for the Private Location
  2. Search for --disable-features= and copy the whole value.
    For example,
    --disable-features=OptimizationGuideModelDownloading,OptimizationHintsFetching,OptimizationTargetPrediction,OptimizationHints,TFLiteLanguageDetectionEnabled,HttpsUpgrades,HttpsFirstBalancedMode
    So, the value is
  3. Append ,TrackingProtection3pcd to the list of values.
    OptimizationGuideModelDownloading,OptimizationHintsFetching,OptimizationTargetPrediction,OptimizationHints,TFLiteLanguageDetectionEnabled,HttpsUpgrades,HttpsFirstBalancedMode,TrackingProtection3pcd
Step 2: Apply the Configuration
This feature can be disabled for all monitors running on the ActiveGate, or for a single monitor.
Note: These changes persist on update, so if new features are disabled by default, you may need to update your snippet.
Option A: All Browser Monitors on the ActiveGate
  1. On the ActiveGate, open the user.properties file
    • C:\\ProgramData\\dynatrace\\synthetic\\config\\user.properties on Windows
    • /var/lib/dynatrace/synthetic/config/user.properties on Linux
  2. Add the following line
    com.ruxit.vuc.poolConfig.playerConfig.toRemoveStartupParams=--disable-features​
  3. Them on the following line, add the --disable-features snippet created earlier after com.ruxit.vuc.poolConfig.playerConfig.additionalStartupParams=--disable-features. For example
    com.ruxit.vuc.poolConfig.playerConfig.additionalStartupParams=--disable-features=OptimizationGuideModelDownloading,OptimizationHintsFetching,OptimizationTargetPrediction,OptimizationHints,TFLiteLanguageDetectionEnabled,HttpsUpgrades,HttpsFirstBalancedMode,TrackingProtection3pcd​
Option B: Single Browser Monitor
  1. Open Monitor → Settings → Recorded Clickpath.
  2. Switch to Script mode.
  3. Add the following snippet into the configuration section and update the value to be the snippet created earlier
    "experimentalProperties": [{
                "name": "disable-features",
                "value": "OptimizationGuideModelDownloading,OptimizationHintsFetching,OptimizationTargetPrediction,OptimizationHints,TFLiteLanguageDetectionEnabled,HttpsUpgrades,HttpsFirstBalancedMode,TrackingProtection3pcd​"
  4. Save your changes
Resize issue view side panel.
What’s next
If this does not resolve the issue, please open a support ticket and provide
  • a link to the affected monitor
  • mention this article and any other troubleshooting steps taken
Related reading
:open_book:  Script mode for Browser monitor configuration
:open_book:  Synthetic Troubleshooting Map
:open_book:  Synthetic Browser Monitor Error Codes
