Summary
After the transition of the Dynatrace Synthetic Recorder to Manifest V3 (MV3), JavaScript injection in Browser Monitors is now based on the Fetch API. As a result, you may notice that XHR actions from third‑party iFrames (iFrames loading a different domain than the main page) are missing from the waterfall analysis, even when you’ve enabled Capture performance metrics for pages loaded in frames in the Advanced setup of browser monitor settings .This article explains why XHR actions from third‑party iFrames are missing in Dynatrace Browser Monitors and shows the additional configuration required to capture them again.
Why Are XHR Actions from Third‑Party iFrames Missing?
With the move to Manifest V3, Dynatrace Synthetic Monitoring now relies on the browser’s Fetch API–based injection model. Chromium’s site isolation behavior limits visibility into network requests initiated from third‑party iFrames.Because of this, XHR actions from those iFrames are excluded unless an additional Chromium startup flag is explicitly enabled.
How to Capture Missing XHR Actions from Third‑Party iFrames
To capture XHR actions from third-party iframes, you must enable
enable an additional Chromium startup flag, disable-site-isolation-trials, in Browser Monitor script mode.
Required Configuration
Add the following flag to chromiumStartupFlags:
"configuration": {
"chromiumStartupFlags": {
"disable-web-security": false,
"disable-site-isolation-trials": true
Important Notes
- By default this flag is not shown in the script, but it has the default value of
disable-site-isolation-trialsisfalse. - Do not overwrite existing Chromium flags
- You may already have flags such as:
disable-web-securityignore-certificate-errors
- If so, keep them and only add or update
Enabling this flag allows Dynatrace Browser Monitors to capture XHR actions originating from third‑party iFrames.
Verification
After applying the configuration:
- Save the Browser Monitor
- Execute the monitor on demand
- Review the waterfall analysis
- Confirm that XHR actions from third‑party iFrames are now visible
If XHR actions are still missing, double‑check that:
- Capture performance metrics for pages loaded in frames in the Advanced setup of browser monitor settings.
- No Chromium flags were accidentally removed.
- The requests originate from third‑party iFrames (different domain).
Frequently Asked Questions
Why does this only affect third‑party iFrames?
Chromium site isolation restricts access to network activity across different domains. Third‑party iFrames fall under these restrictions unless site isolation trials are disabled.
Does this affect first‑party iFrames?
No. XHR actions from first‑party iFrames (same domain as the main page) continue to be captured without additional configuration.
Is this behavior specific to MV3?
Yes. This behavior was introduced after the Synthetic Recorder transitioned to Manifest V3 and the Fetch API–based injection model.
What’s Next
If enabling disable-site-isolation-trials doesn’t resolve the issue, open a support chat and provide:
- A link to the Browser Monitor
- Confirmation that the flag is enabled
- Example URLs of affected third‑party iFrames
Related reading
Script mode for Browser Monitor configuration
