Building a custom extension in an isolated network
Here my how-to build a custom extension in a place without internet access, which is my case:
References
Prerequisites
Python distribution
The Python version must be the same than the one used by the ActiveGates: Python 3.10.15
./remotepluginmodule/agent/res/dsruntime/python3.10/bin/python3 --version
Python 3.10.15
Download the required Python source from GitHub - python/cpython: The Python programming language · GitHub.
Compile it:
cd cpython
./configure --prefix=<path to your new Python> \
--with-ensurepip=install
make -j$((`nproc`+1))
make install
<path to your new Python>/bin/python3 –version
Python 3.10.15
Now we need the Python packages. Download dt-cli and dt-extensions-sdk packages (see in the ref for where to download from) to be able to build your own extension. Download extra required extensions from the pypi web site.
Move the packages in a dedicated folder on your isolated machine.
Now, install the packages:
dnf install -y rust rust-toolset rust-srpm-macros libffi-devel
export PATH=“<path to your new Python>/bin:${PATH}”
cd <path to your local package repo>
pip3 install --no-index --find-links=<path to your local package repo> <package name>
dt-sdk --help
Usage: dt-sdk [OPTIONS] COMMAND [ARGS]
dt --help
Usage: dt [OPTIONS] COMMAND [ARGS]…
Signature
Extensions require to be signed with a certificate. This certificate must be present in the cluster and in targets (ActiveGate for remote extension, OneAgent for local extension). The extension is checked against the certificate before being executed, to prevent any intrusion of malicious code.
Generation of the certificate on your development machine:
cd <path to your certificate>
dt extension genca --no-ca-passphrase
Generating CA…
Wrote CA private key: ./ca.key
Wrote CA certificate: ./ca.pem
mv ca.pem custom_extension_ca.pem
mv ./ca.key custom_extension_ca.key
dt extension generate-developer-pem -o custom_extension_developer.pem --ca-crt custom_extension_ca.pem --ca-key custom_extension_ca.key --name DXC
Loading CA private key custom_extension_ca.key
Loading CA certificate custom_extension_ca.pem
Generating developer certificate…
Wrote developer certificate: custom_extension_developer.pem
Wrote developer private key: custom_extension_developer.pem
Kind of target Place
ClusterPut the custom_extension_ca.pem in GUI => Credential vault
ActiveGate./remotepluginmodule/agent/conf/certificates/custom_extension_ca.pem
UNIX OneAgent/var/lib/dynatrace/oneagent/agent/config/certificatesBeware: the folder is own by root
Windows OneAgent/project/eag0/config/remotepluginmodule/agent/conf/certificates
Extension build
After developing your extension according the documentation
You need to compile
export PIP_NO_INDEX=1
cd <path to your custom extension>
dt-sdk build --find-links=<path to your local package repo> --private-key  <path to your certificate>/custom_extension_developer.pem
Gautier
