Calculate time difference between two records
I want to calculate the time difference the current record and previous record, until the end of the record.
example,
Thank you.
Hi.
The easiest way to do this is to convert your DateTime values and then subtract the start time from the end time.
| fieldsAdd myendtime = toTimestamp(myendtime), mystarttime = toTimestamp(mystarttime)<br>| fieldsAdd myduration = myendtime - mystarttime
You might need to perform the same subtraction multiple times until the end of the record.
Let me know if this works for you đꙂ
Window function are not available yet, but it is possible under certain limitations using collectArray , array sorting, and arrayDelta functions and your data set has well defined order:
data
  record(timestamp=now(), tx="a"),
  record(timestamp=now()+500ms, tx="b"),
  record(timestamp=now()+2s, tx="c"),
  record(timestamp=now()+3s, tx="d"),
  record(timestamp=now()+4s, tx="e"),
  record(timestamp=now()+5s, tx="f"),
  record(timestamp=now()+13s, tx="g"),
  record(timestamp=now()+14s, tx="h"),
  record(timestamp=now()+15s, tx="i"),
  record(timestamp=now()+16s, tx="j")
| sort timestamp asc
| fieldsAdd d = record(t=timestamp, tx)
| summarize d = collectArray(d)
| fieldsAdd d  =arraySort(d, direction:"ascending")
| fieldsAdd dt = arrayDelta(iCollectArray(unixNanosFromTimestamp(d[][t])))
| fields d = record( timestamp=d[][t], dt = duration(dt[], unit:"ns"), tx=d[][tx])
| expand d
| fields timestamp=d[timestamp], dt=d[dt], tx=d[tx]
| sort timestamp asc
Result looks like this:
max number of records processed using this method is 131072 according to documentation: Aggregation functions — Dynatrace Docs
