Hello Team,
How does OpenPipeline calculate the distribution percentage of logs? Is it based on a specific time window, such as the last 2 hours, or is it calculated over all logs shipped?
While I am not 100% sure on this, I noticed that the tooltip on the āRecords over timeā column gives a timestamp which indicates a window of āLast 30 minutesā. I am guessing that the distribution is using the same data set as well.
If you need more flexibility or detail, you can use the built-in āOpenPipeline usage overviewā dashboard that was recently added into the platform as a starting point.
Thanks @marco_irmer ,I also noticed that the ārecord over timeā is showing data only for the last 30 minutes, so I just want to confirm whether the percentage is also being calculated based on the same data.
yes, I can confirm that the time window that is being looked at is 30min. The chart shows relative development over time -each chart being on its own scale; the percentage is calculated from the sum over 30min.
All of this is based on number of records not on the volume.
