We’re ingesting data for external integrations using the Environment V2 logs ingest API. There is an attribute value that’s incremented every second that our Source System is running. With a 1 minute post interval at 60 seconds, we would expect to see the value go from { custom.uptime = 500000 } to { custom.uptime = 500060 }. Starting values can be different for each entity.
For Log Metrics, is there a way to configure a metric that would use the difference between the ‘custom.uptime’ value between Time Series? Our dashboard/alert would contain something split by entities, like (custom.uptime[t2] - custom.uptime[t1] / log.timestamp[t2] - log.timestamp[t1]) < 1.
Thank you
