We would like to run the SQL query daily ones to pull job data and ingest a metric. That metric data used for Davis AI prediction. Is there a way to ingest metric with past dated timestamp?
At the moment, you can ingest data till 60 minutes in the past, and 10 minutes in the future.
BTW, you can upvote the corresponding Product Idea: https://community.dynatrace.com/t5/Product-ideas/Metrics-ingestion-beyond-one-hour-in-the-past/idc-p/251871
