Would like to know if Dynatrace Synthetics (either within ActiveGate agent or within the script) can utilize the routing information found in the WPAD.DAT file rather than routing through the proxy on private Synthetic locations?
Thank you for your question. This is not currently supported. However, it is being considered with no time frame for availability.
