Is there a way to monitor an unmanaged Azure SQL Server database? I see no option for extensions in Azure SQL. And in setting->…->supported technologies I see MS SQL but it doesn’t mention Azure. Please advise.
Thank you.
Thank you.
Dynatrace covers a bunch of SQL instances for Azure: All Azure cloud services — Dynatrace Docs
Azure SQL Servers (Built in)
Azure database for MySQL
Azure database for PostgreSQL
Azure SQL Data Warehouse
Azure SQL Hyperscale
Azure SQL Managed Instance
