Does Dynatrace support monitoring of the Azure CosmosDB SQL API? The supported technologies page does not make a mention of it, so I’m assuming it doesn’t. If I’m wrong, great; if DT doesn’t support it now, will it support it in the future?
Any news concerning? I’m interested.
We added Azure CosmosDB on the supported technologies page. For more details regarding supported technologies see https://www.dynatrace.com/support/help/technology-support/supported-technologies-and-versions/
Hi, any update on support for SQL API for CosmosDB? Thanks.
Hi, following up. Any updates on support for SQL API for Cosmos DB? Our team is using the Java SDK to access Cosmos DB and we do not see any metrics being collected by Dynatrace.
