Hello friends, is there a config that can do such a thing ?
(Avoiding the traffic collected by Environment Active Gate to be re-routed to the Cluster Ag)
Thank you
Thank you
Yes, you can.
1. You have to set up MSGRouter = false at Cluster AG.
In that case Environment AG will hae to pick a cluster node to route the traffic.
2. Around June 2020 we will deliver a new feature called Network Zones - that will enable you to configure how you would like to set up routing path.
Can I be specific on which Env Active Gate I do not want to communicate with the Cluster Active Gate?
When we introduce Network Zones - yes. Now you can only block traffic with your firewall or iptables.
Thank you very much @Radoslaw S.
Like @Radoslaw S. said, until the Network Zones feature is released, users will have to resort to firewall blocks. We had to block all oneagent traffic out to our DMZ activegate that supports our UFO’s Davis, Synthetics and so much more.
… network zones… ![]()
gahh, Typo. Thanks ![]()
