Setup 3 Environment ActiveGates and 2 Extension ActiveGates separately
I want to setup 3 Environment AG and 2 Extension AG separately .. i understand installation will have same installer .. but what changes needs to be done for Extension AG so it will only act for Extension capability ..
Regards
Sachin
@SachinJindal
Check out the Configuration properties and parameters of ActiveGate:
In the first 3, dedicate them to OneAgent routing. Guarantee that you have the following, while disabling whatever you don’t need.
  • [collector]
    MSGrouter = true
In the other 2, guarantee that the extension_controller section is enabled, while disabling routing.
Check whether you also need the other modules. restart ActiveGates and check in Deployment Status that they are working as intended…
Hello Antonio,
i have installed default AG and created a separate Network zone and Group for isolation .. My requirement is i wanted this AG only be doing Extension jobs .. but not really sure what needs to be disabled ..
Sachin
You can disable all of them, except “Extensions” https://docs.dynatrace.com/docs/shortlink/sgw-configure#modules
Best regards
Thanks Anton .. i did disable most of them and see this Oneagent routing still present which i wanted to disable…
Note :- Reason i wanted to do this i have created 3 AG with default network zone (Environment AG’s) and 2 with XXX network zone (Extension AG’s) .. currently oneagent is sending the traffic to all of the AG’s but i wanted only to sent to default Environment AG only
:~ $ agctl modules get
Enabled modules:
[autoupdate, extension_controller]
You can configure OneAgent to AGs network zone and it would try to use that AG as first option.
Best regards
Hello @AntonPineiro  - Have tried this option still same issue..
Sachin
@SachinJindal
Do the following and restart AG.
[collector]
MSGrouter = false
Thanks this is working..
