Can we filter distributed traces for Request Header specially the referer part of it?
Can we filter distributed traces for request headers?
Hi Gauri,
Yes you can.  First you need to create a ‘request attribute’ , you can do this as ‘global’ or filtered to a specific application or component.   More info here: Request attributes | Dynatrace Docs
* You can use this approach to make any field searchable within distributed trace.
As a request attribute, you can call out the ‘Referer’ which will be captured and then made searchable.
global capture example below.
Once in distributed traces, you can then search / filter using the following
- All matching instances
- specific instance
Enjoy
