Capacitor HTTP/Native HTTP not working with Cordova-Plugin
We have a case where we instrument our Cordova/Capacitor Mobile App with Dynatrace.
Cordova Plugin v 2.279.2.
However if we have the following Setting
  "plugins": {
    "CapacitorHttp": {
      "enabled": true
we experience error messages in the Angular part.
Error when sending batch of logs to server TypeError: Ze.addEventListener is not a function TypeError: Ze. addEventListener is not a function
at d. <anonymous> (http.mis:2176:21)
at d._zoneSubscribe (zone-patch-rxis.is: 68:50)
at d. trySubscribe (Observable. js: 37:25)
at Observable. js: 31:30
at K (errorContext.js: 19:9)
at d. subscribe (Observable. is: 22:9)
Once we disable CapacitorHttp  we don’t have any issues, however the Application requires this setting to run properly.
Details
Capacitor Version 5.5.0
Tested combinations
  • JS Agent with Native http → Throws JS Error (In Angular Core, http.mjs)
  • o Object instance is window.XMLHttpRequest → Object
  • JS Agent without Native http → Works
  • o Object instance is XMLHttpRequest → XMLHttpRequestEventTarget → EventTarget
  • Native http alone → Works
Assumption
JS Agent also uses monkey patching and gets in the way with Native-http plugin.
Anyone has the encountered a similar issue? any solutions? Thanks in advance :slightly_smiling_face:
I’ve run into a similar issue between Capacitor, the Dynatrace Cordova plugin and cordova-plugin-wkwebview-file-xhr for native requests. The injected Dynatrace JS on the index page will throw a series of RangeErrors that prevent requests from completing. No solution yet, however cordova-plugin-advanced-http seems to play nicely with the Capacitor and the Dynatrace Cordova plugin.
Please open a support ticket and we will take a look. This is way to complex for the community board here.
I am running into the same problem with our application. Was this resolved, or was there some other outcome. Would be good to know.
Hi there.
Are you using the latest plugin version (2.347.1)? We haven’t really seen any support tickets for this issue. I would suggest creating a support ticket with the steps to reproduce and console logs showing the full error etc. so that we can take a further look into the issue. As Matthias mentioned, this is a bit more complex of an issue for the community board.
Thanks!
