I am looking for documentation to integrate dynatrace in ionic capacitor enabled app.
is it possible? can dynatrace support Ionic with capacitor?
Looking for your feedback as soon as possible.
Durgesh Patel
Durgesh Patel
Hello @durgesh ,
Here is the list of all technologies supported by Dynatrace:
https://www.dynatrace.com/support/help/technology-support/supported-technologies-and-versions/
Capacitor isn’t on it, but the Dynatrace Cordova Plugin has added support to Capacitor. You can check it here:
https://www.npmjs.com/package/@dynatrace/cordova-plugin#capacitor-instrumentation
https://www.dynatrace.com/support/help/how-to-use-dynatrace/real-user-monitoring/setup-and-configura…
