Can anyone provide what the capture limits (oneagent) of business events are on the payload (request/response) are?
I have a situation where, although requests itself are captured and details are extracted from headers, the response payload (JSON) and the captured data fields that depend on it are empty. The current assumption is that (since the response can’t be null) that a limit kicks in and the payload is ignored if it exceeds a certain size? (Which makes sense performance -wise, but it would be good to know)
OneAgent limits:
• Max req/res body payload size 64132 bytes (~64 KiB)
• Period length 1000 (1 second)
• Max events in a period 200
• Max payload in a period (1 MiB)
The body is not captured, or it cannot be safely interpreted (e.g. a truncated JSON payload would not be parsed or any fields extracted) - you would get a null value.
I asked support to extend our capture limit and they increased it to 128Kb (works fine for us now)
