For Business event capture we use specific fields from response/ request body
Want to check how this values are read from response / request body before saving data to grails
will this save the entire response / request body to grails?
will Dynatrace scans through the whole request / response body before it captures specific fields from response / request body
To clarify your question, are you asking about the payload for how these Business Events are captured?
If you’re asking about generally, BizEvents are captured through a variety of ways (RUM, Log Files, OA ingestions, etc.). A good blog post on this can be documented here:
Right , question was on payload data from business event capture. How does Dynatrace capture and read these values from payload after configuring Business event capture for these request / payloads?
For example:
I have configured a business event capture rule for a field (field A) in payload. When business event captures this field using the business event capture :
will Dynatrace scans through the whole request / response body before it captures specific fields from response / request body.
If you set it to save only the X key and value from a payload, will only save that. Setting it to save the full RQ/RS will save the full RQ/RS. Otherwise, the cost of saving the full RQ/RS should impact the business event capture. If you save Field A and later search for Field B, that info will not exist.
