Business Events
Good afternoon, what is the difference between capturing incoming and outgoing business events? Additionally, if I want to capture it from a specific technology, for example, I want to capture it from nginx technology and not from another
Hi @carlos_carreno , an example of incoming business events would be the events generated based on the requests application receives from clients or other services. They typically represent requests or data coming into your application. These can be captured from incoming HTTP requests to your application or API calls etc.,
Outgoing business events would be data leaving your application or the data sent to external endpoints from your application , examples would be Http response to users or API calls to external endpoints  etc.,
https://docs.dynatrace.com/docs/shortlink/ba-business-events-capturing
I think what you can capture depends on the rules you specifically configure
https://docs.dynatrace.com/docs/shortlink/ba-business-events-capturing#configure-sources
