Change/Delete Custom Metrics Through UI
I see that we are only able configure custom metrics via API. Is that true or can we change the naming, or delete them all together from Dynatrace UI?
Okay I’ve discovered that, we can change it through UI. I’ve written the path down below for future references.
Settings → Server-Side Monitoring → Calculated Service Metrics
thank you, @serhat_balik, for sharing!
