I am working with Dynatrace Managed and want to include performance test analysis/validation as part of the build pipeline to pass or fail a test.
I have watched the online perf clinic from October 2017 which highlights the integration possible through Neoload. This demonstrated that you can tag requests as in AppMon and register tests as events in Dynatrace using Neoload but I am using Jmeter and LoadRunner. I’ve found this page around registering third party events but the documentation for the API is very limited: https://www.dynatrace.com/support/help/dynatrace-api/events/how-do-i-push-events-from-3rd-party-systems/.
Is this the correct way to start/stop tests? If so, can the docs be extended with more explanation around API request/response parameters and further examples on how to use this for test events?
Following on from this, it does not seem that it is possible to use Dynatrace to compare tests in a pipeline scenario so registering tests is of little value in this scenario.
Registering a maintenance window like was mentioned in the perf clinic for helping the AI component would not work for this CI/CD case as tests are only run when builds are triggered which is only 1-2 times a day max, so a maintenance window would almost always be set.
This post also talks about approaches for performance engineering but does not mention that it is possible to do any kind of automated analysis. https://www.dynatrace.com/news/blog/load-testing-r…
