JMeter integration consume DDU?
I think if you push back events or metrics about the tests via DT API endpoints the answer is yes.
Dynatrace and load testing tools integration | Dynatrace Docs
Otherwise if you use only request attributes for analyse the tests I thnik the answer is no, becasue there is not any external data ingestion to DT.
Dynatrace and JMeter integration | Dynatrace Docs
I hope it helps.
Best regards,
Mizső
