Integration with Jmeter
I am facing issue while integrating jmeter with dynatrace, even after following all the steps mentioned in the dynatrace documentation. Please refer the attached file.
Hello @akshatpandey36 ,
Did you check if your headers x-dynatrace.* are allowed via Loadbalancer (F5)?
Please find this link Firewall constraints for RUM | Dynatrace Documentation
You have also to ensure where you will store your request attribute, “capture server side” wildly used and enough. Also about HTTP method POST or GET.
It is not mandatory to use , to the letter, x-dynatrace-test, feel free to use x-dynatrace-yourvalue.
yourvalue = name of your app and environment for instance.
Some useful links :
JMETER integration : Dynatrace and load testing tools integration | Dynatrace Documentation
Capture request attributes based on web request data | Dynatrace Documentation
Our company has as well plugin forJMeter that is sending metrics from generator love to Dynatrace. You can compare results from DT and generator on single dashboard :slightly_smiling_face:
