Citrix Hypervisor
Hi, Whether dynatrace supports monitoring of the Citrix Hypervisor?
Hello @Lwl
Citrix XenServer hypervisor? I doubt Dynatrace supports. Can you elaborate the requirement in detailed. what is required from monitoring.
In mean while please refer below doc if this helps.
  • https://www.dynatrace.com/hub/detail/citrix-virtual-apps-and-desktops-v2/
    • Citrix VDA - Monitor the individual user sessions, by activating the extension on each Virtual Delivery Agent
    • Citrix Powershell SDK - Monitor the entire Citrix Environment, by activating the extension on a machine that has the Citrix Powershell SDK installed. Usually where Citrix Studio is installed or a Delivery Controller
Just FYI - Don’t go by this doc as this is deprecating
Cheers!
RN
Hi @RazTN7
thank you
