Citrix VDI Monitoring
Dear All,
Can we monitor the Citrix VDI? if YES
What are the best practices?
Babar
You can install a OneAgent to get additional insight into the desktop, and you can also use our Citrix Virtual Apps and Desktops Extension to get more information about the delivery chain.
Performance clinic: Performance Clinic - SAP and Citrix Enterprise Application Monitoring with Dynatrace
Blog post: Optimize Citrix platform performance and user experience
Help information: Extensions — Dynatrace Docs
Hello @Michael L.
Thank you for sharing the links.
I guess my query was not clear. The customer made a VDI setup on the Windows Hyper-V, so the internal/external users will be landed on those VDI/VMs during the login and then the session/communication will be started from VDI to backend Citrix servers.
How can we monitor such type of setup with the minimum utilization of licensing?
Babar
From the VDI to the backend Citrix servers the links I added will help you out.
As for insight into the Windows Hyper-V, you could either install a OneAgent into each VDI (a lot of insight but consumes Host Units), or write an ActiveGate plugin to poll out health information from Hyper-V (less insight but also less license utilization).
Hello @Michael L.
Once again, thank you for your suggestions.
It means we can ignore the OneAgent, and the extensions/plugins can provide us the maximum information.
Babar
Shameless plug: If you want help with the creation of the plugin, you can reach out to our services organization.
Good luck!
Mike
Hello @Michael L.
If I am not mistaken, you are referring to the ActiveGate plugin to poll out health information from Hyper-V.
Babar
Indeed.
Mike
Hello @Michael L.
Thank you for all this information.
Babar
