I’m researching the ability to clone or copy dashboards from UAT to Prod
Thanks @PacoPorro your doc was very helpful
How to do it in the new version of Dashboards (not Dashboards Classic)? Thanks
Basically you should follow these steps:
Download Dashboard in UAT:
- Navigate to the new Dashboards section in your UAT environment.
- Select the dashboard you want to download.
- Click on the Download button to save the dashboard configuration file to your local system.
Upload Dashboard in PROD:
- Switch to your PROD environment in Dynatrace.
- Go to the new Dashboards section.
- Click on the Upload button.
- Select the previously downloaded dashboard configuration file from your local system.
- Confirm the upload to complete the process.
If you go to your dashboard and download the JSON file. You can then import the JSON file into you Prod environment.
