Close problem in new Problems app
Hi all,
I am now testing with the features on the new UI. However, I have found we can only close the problem manually in the Problems classic page. The new Problems app seems does not have the feature available.
@Hillman - yes the new problems app does not yet have the option to close the problem
Maybe it might be a product idea.
Best regards
Hello @Hillman
The highlighted concern is available at the classic problems page, not available yet in the problems app.
Let’s stay tuned for the upcoming releases or feel free to proceed the suggestion provided by @AntonPineiro
Keep up the good work,
KR,
Peter.
A product idea was already raised about this.
Hi, there is a update about this?
It’s been more than a year now, and I still can’t close problems in the problem app.
Still waiting on this??? Um not quite ready for prime time I guess.  This seems like a pretty basic function that should have easily been ported over from the “classic” dashboard.
2026 and still no Resolve Problem button on new Problems app. If you are not going to put it in, update the AI generated instructions that still refer to a Resolve Problem option in the non existent Actions menu it talks about.
  1. Open the Problem:
    • Click on the problem to open its detailed view.
  2. Mark as Resolved:
    • In the problem details view, look for the Actions menu or a similar option (usually in the top-right corner).
    • Select Mark as Resolved or a similar option to manually resolve the problem.
Will this button be added soon? Its been almost 2 years now. Its a fairly basic feature that was removed and is needed.
Hi everyone,
I’m happy to share the news
Manual “Close problem” is now available in the new Problems app with Dynatrace SaaS 1.344 (Sprint 344).
You can close from the list (including bulk close up to 50) or from a single problem’s details, and add a closing comment.
We know this has been a long wait for a basic control;
thanks for the (very justified) nudges and for hanging in there.
Release notes
Are there plans to allow closing more than 50 at a time?  We often have misconfigured auto-scaling hosts that create 100’s of “Host availability” problems we close manually with the classic app.
I understand your demand;
We are already working on 2 potential solutions for your case:
1. short term, you will be able to take more control over the problem creation itself, in order to reduce the number of problems that are created
2. in the long term we want to support the full problem lifecycle via workflows, which will allow you to close problems in an automated way.
