Hey community,
I need your assistance with something:
I want to extract a list of acknowledged problems, that inside the list I will be able to see which user closed each problem.
Is it possible?
Thank you in advance!
Hey community,
Is it possible?
Hi @YuvalKonstanti,
You can use Dynatrace problem api v2, where you can fetch problem list and loop through and filter based on your requirement apart from this you can directly pass query parameters get specific details.
Please check below documentation.
Try can use the API: Problems API v2 - GET problems details — Dynatrace Docs
Probably in the “Comment” field you should find info who changed the status of this issue.
Radek
Thank you for the reply guys.
I don’t really get how to use it, I saw that there is an option to add:
authorName - which is the user who wrote the comment.
Can you please help me understand how I’m using it?
I’m using: “https://{environmentid}.live.dynatrace.com/api/v2/problems” but I don’t get anything. Do I need to add this comment field to see the user?
Thank you in advance guys. I’m new to this and really appreciate your help!
Hello @YuvalKonstanti,
you can add the recentComment as a field to get the comments and you can use one of the following URLs
https://{environmentid}.apps.dynatrace.com/platform/classic/environment-api/v2/problems?fields=recentComments
as for the comment related to closing the problem you will find the context “dynatrace-problem-close”
“context”:“dynatrace-problem-close”
This is how it should work
Hi @YuvalKonstanti,
You can use recentComments in query parameters.
See that’s what @Mohamed_Hamdy wrote about it;)
Sorry @radek_jasinski my bad.
Hey Guys! many thanks for the help!
So right now I managed to extract the data, but I encountered two problems:
“recentComments” will add the comments to the problems, but can I see only the manually closed problems? (status = closed will not do the job because it’s putting together manually closed and automatically closed problems).
Second thing is this:
“Page size can’t be larger than 10 if the fields parameter is set”.
Someone had any luck with finding a good solution for that? Because my goal is to extract a lot more than that, for example, the whole problems for a one day.
Thank you all!!
