I will be taking two certifications in the coming days: Cloud Ops and Saas Upgrade.
Do you have any other helpful materials besides those on University?
Radek
Hi @radek_jasinski ,
regarding CloudOps you might find some useful tips in the following link
https://community.dynatrace.com/t5/Dynatrace-tips/Services-Delivery-Certification-CloudOps-Tips/m-p/221061#M997
as for the SaaS upgrade, I don’t have any tips for it as I haven’t completed it yet, however, I can see that the university course might be enough as it has rich and useful content
@Mohamed_Hamdy Thanks for the hint. I’m now working on some summary of the material. When I prepare it I will share it with you:)
Hi @radek_jasinski @Mohamed_Hamdy ,
I’m planning to write SaaS Upgrade Service Delivery Certification. Any guidance based on your experience?
Navendu
Hi @NavenduGupta ,
To effectively prepare, you can follow these steps:
- Complete the Course at least Twice:
Go through the course at least twice to ensure you fully understand the SaaS upgrade mechanics and make sure that you memorize the key takeaways for each video.
Dynatrace University Course
- Understand Knowledge Areas:
Familiarize yourself with the key knowledge areas and their weight for the exam.
Certification Preparation
- Know the Phases:
Gain a deep understanding of the Run, Upgrade, and Planning phases, and the steps involved in each.
- Product Limits and SaaS Differences:
Be clear on the product limits and how they differ in a SaaS environment and if these limits could have an impact on the license
- ActiveGate and OneAgent Migration:
Learn the recommended options and steps for migrating ActiveGate and OneAgent.
- Monaco Configuration:
Understand how Monaco works, the commonly used commands, and how to configure attributes across multiple Monaco configurations.
- Pros and Cons of ActiveGate Migration Options:
Be familiar with the pros and cons of different ActiveGate migration options, including which option removes extensions. Make sure to review what to focus on before migrating the AG extension, and identify the key configuration files to consider.
- Agentless and Mobile App Migration:
Understand the process for migrating agentless and mobile applications and how to confirm if beacon new endpoint included in agentless js
- The use of the Automation Tools for OneAgent:
Know the role of automation tools like Puppet which is used for OneAgent deployment.
- Settings 2.0 Compatibility:
Learn how to identify which settings are supported by Settings 2.0 from the UI
Another valuable option, though not typically covered in exams, is the SaaS Upgrade Assistant, which is especially useful when upgrading to Dynatrace SaaS. Familiarizing yourself with this App can greatly streamline the upgrade process. For more detailed guidance, refer to the resources below:
These resources will provide comprehensive insights into ensuring a smooth transition to Dynatrace SaaS.
Mohamed
