đŸŽ„ How to effectively upgrade from Dynatrace Managed to SaaS
SaaS Upgrade from Managed to SaaS is a holistic process to ensure you can successfully upgrade your observability platform and leverage Grail-enabled capabilities like Log Management and Analytics, AppEngine, Workflows, and more! To upgrade to SaaS, you need a SaaS environment, and then you’ll want to replicate your configuration build over the years and migrate OneAgents to start collecting data.
In this Observability Clinic with Andreas Grabner @andreas_grabner, Radoslaw Szulgo @Radoslaw_Szulgo explains how Dynatrace SaaS Upgrade Assistant and Remote Configuration Management can be leveraged to upgrade from Dynatrace Managed to SaaS effectively.
Radek shows us the actual life use case on exporting the configuration from the Managed environment, importing it to the SaaS Upgrade Assistant, and running it. Then, Radek shows the remote configuration management in action to modify the communication settings of OneAgents to migrate them to SaaS easily.
To learn more, please check out the following links:
SaaS Upgrade Guide: SaaS Upgrade Assistant — Dynatrace Managed Docs
SaaS Upgrade Readiness Assessment: Interactive Calculators & Quizzes
SaaS Upgrade Community Forum: https://dynatr.ac/3QJbBE2
Chapter List:
00:00 - Introduction
01:08 - SaaS Upgrade Process
01:47 - Essential steps to set up your SaaS environment
03:54 - SaaS Upgrade Assistant Overview
04:52 - Remote Configuration Management Overview
06:20 - Live Demo
09:02 - Export configuration from Dynatrace Managed
09:46 - SaaS Upgrade Assistant installation and run
19:59 - OneAgent migration
39:14 - Additional Resources
Recording on the Dynatrace University
Subscribe to our YT channel
Stay up-to-date with Dynatrace! Follow us on Facebook, Instagram, LinkedIn, Twitter, Twitch
Nice demo! :money_mouth_face:
Just watched this video.
Really amazed by the App â€œSAAS Upgrade Assistant”, and how fast the hosts are automatically reporting data to SAAS cluster after modifying the communication.
@AgataWlodarczyk Thanks for sharing.
