With the SaaS Upgrade Assistant, most of the configuration and dashboards of a Managed environment can be migrated automatically to a SaaS environment. You can simply export the configuration and dashboards from your Managed environment, upload it to the SaaS Upgrade Assistant on the target SaaS environment, and get started.
- Check on your import progress via the upgrade status tracking.
- Browse imported configurations and review failed configurations.
- Correct failed configurations with an edit form or use bulk mode to update at once.
- Leverage preview changes to make sure the update is correct.
