We have a client experiencing inconsistent infrastructure performance.
It would be nice for Dynatrace to provide a seamless capability for customers wishing to migrate from Managed to SAAS or vice versa without loss of data.
The same way we can replicate a node to another node, theoretically it should be possible to migrate a managed cluster node to a SAAS environment or vice versa
SaaS has slightly different deployment, so restoring managed nodes to SaaS is impossible. However, you might consider running Managed on cloud infrastructure or migrating your configuration to a SaaS tenant (data itself is not migrated).
Data migration is unfortunately not feasible between these two products. Configuration is the only piece that could be copied from Managed to SaaS.
I guess currently not possible but i believe Dynatrace should begin to consider this capability especially for clients who have run on Managed for some time and suddenly experience infrastructure instability
