Hi Folks,
At one of our customers we should exclude some cipher suites from the Cluster Active Gate (with public internet leg).
We have followed the documentation and tried 3 types configuration of exluding 3DES chiper suites without success. We have checked the results with nmap, but nothing has changed after the CAG configuration and restart.
Cipher configuration for ActiveGate | Dynatrace Docs
We always made a change in the CAG config.properties file. These were the 3 types change method.
1. [com.compuware.apm.webserver]
excluded-ciphers = TLS_DHE_RSA_WITH_3DES_EDE_CBC_SHA,TLS_ECDHE_RSA_WITH_3DES_EDE_CBC_SHA,TLS_RSA_WITH_3DES_EDE_CBC_SHA,TLS_DHE_RSA_WITH_3DES_EDE_CBC_SHA,TLS_ECDHE_RSA_WITH_3DES_EDE_CBC_SHA,TLS_RSA_WITH_3DES_EDE_CBC_SHA,TLS_DHE_RSA_WITH_3DES_EDE_CBC_SHA,TLS_ECDHE_RSA_WITH_3DES_EDE_CBC_SHA,TLS_RSA_WITH_3DES_EDE_CBC_SHA
OR
2. [com.compuware.apm.webserver]
excluded-ciphers = TLS_ECDHE_RSA_WITH_3DES_
excluded-ciphers = TLS_RSA_WITH_3DES_
OR
3. [com.compuware.apm.webserver]
excluded-ciphers = _3DES_
The results always were the same after restart of the CAG (we tried stop and start also beside restart option). 3DES chiper suites were still available.
nmap -sV --script ssl-enum-ciphers -p 443 localhost
Starting Nmap 6.40 ( http://nmap.org ) at 2023-01-19 10:24 CET
Nmap scan report for localhost (127.0.0.1)
Host is up (0.000042s latency).
rDNS record for 127.0.0.1: localhost.localdomain
PORT STATE SERVICE VERSION
443/tcp open ssl/http Apache httpd
| ssl-enum-ciphers:
| SSLv3: No supported ciphers found
| TLSv1.0:
| ciphers:
| TLS_DHE_RSA_WITH_3DES_EDE_CBC_SHA - strong
| TLS_DHE_RSA_WITH_AES_128_CBC_SHA - strong
| TLS_DHE_RSA_WITH_AES_256_CBC_SHA - strong
| TLS_DHE_RSA_WITH_CAMELLIA_128_CBC_SHA - strong
| TLS_DHE_RSA_WITH_CAMELLIA_256_CBC_SHA - strong
| TLS_ECDHE_RSA_WITH_3DES_EDE_CBC_SHA - strong
| TLS_ECDHE_RSA_WITH_AES_128_CBC_SHA - strong
| TLS_ECDHE_RSA_WITH_AES_256_CBC_SHA - strong
| TLS_RSA_WITH_3DES_EDE_CBC_SHA - strong
| TLS_RSA_WITH_AES_128_CBC_SHA - strong
| TLS_RSA_WITH_AES_256_CBC_SHA - strong
| TLS_RSA_WITH_CAMELLIA_128_CBC_SHA - strong
| TLS_RSA_WITH_CAMELLIA_256_CBC_SHA - strong
| compressors:
| NULL
| TLSv1.1:
| ciphers:
| compressors:
| NULL
| TLSv1.2:
| ciphers:
| TLS_DHE_RSA_WITH_AES_128_CBC_SHA256 - strong
| TLS_DHE_RSA_WITH_AES_128_GCM_SHA256 - strong
| TLS_DHE_RSA_WITH_AES_256_CBC_SHA256 - strong
| TLS_DHE_RSA_WITH_AES_256_GCM_SHA384 - strong
| TLS_ECDHE_RSA_WITH_AES_128_CBC_SHA256 - strong
| TLS_ECDHE_RSA_WITH_AES_128_GCM_SHA256 - strong
| TLS_ECDHE_RSA_WITH_AES_256_CBC_SHA384 - strong
| TLS_ECDHE_RSA_WITH_AES_256_GCM_SHA384 - strong
| TLS_RSA_WITH_AES_128_CBC_SHA256 - strong
| TLS_RSA_WITH_AES_128_GCM_SHA256 - strong
| TLS_RSA_WITH_AES_256_CBC_SHA256 - strong
| TLS_RSA_WITH_AES_256_GCM_SHA384 - strong
| compressors:
| NULL
|_ least strength: strong
Service detection performed. Please report any incorrect results at Nmap OS/Service Fingerprint and Correction Submission Page .
Nmap done: 1 IP address (1 host up) scanned in 17.69 seconds
Does anyone have experience with it?
Thanks in advance.
Best regards,
Mizső
