In a Managed Cluster, how to get the id of each node (the one used in the event message and backup).
A mapping of the id with the hostname or/and the IP address would be fine.
Go to cmc and then select nodedetails and you can extract nodeId form url:
https://{DOMAIN_PREFIX}.dynatrace-managed.com/cmc#cm/nodedetails;nodeId=1
regards
Marek
Is it possible to change the node id? we have reinstalled a node and it use to have id 5 now it has a different id 11 and we would like to change it back to 5. is that possible?
